CCTL, CCT, cam chain guide
Old Mar 10, 2014 | 10:15 PM
icedmind's Avatar
Default CCTL, CCT, cam chain guide
Hi all,
I had my F4i for about a year, recently the CCTL/CCT noise re-appeared and it rattles all over again(3k, 5.5k rev)
I had replaced it once before with OEM one(and once before that by the previous owner); took it out few days ago, soaked it in oil and re installed it(the tensioner work as good as new, springs got good tension), it went on working for about 200miles and now the noise came back
I have read a lot about manual cam chain tensioner, matter of fact i got one on my heavily modded DRZ which suffer similarly
Just wondering if the cam chain tensioner is the problem or if the cam chain guide is worn then where and which part should i look at to start off with?
Thanks
Old Mar 11, 2014 | 07:57 PM
boredandstroked's Avatar
Its just the lifter not the guide. Either be ok with replacing every 20-30k miles with original or else get the manual one.
Old Mar 18, 2014 | 06:30 PM
Joshua Rodriguez's Avatar
do you have to adjust the manual one at all or is it put it in, adjust it and be done? need to replace mine but cant decide on manual or OEM.
JetPilotMike
Apr 28, 2011 04:37 PM
stinemonster
Sep 1, 2008 11:01 PM
stewje55
Apr 21, 2008 10:04 PM
five0addict
Jul 25, 2006 10:44 PM
SkiBr82
Jul 17, 2006 05:44 AM
