CCT Question
Old Mar 11, 2008 | 04:52 PM
F4iFreak's Avatar
Default CCT Question
So I bought a new cct for my F4i and my friend was playing with it and took the key out before it was in. Soo do I need to get a new one or can you back it out again? Thanks
Old Mar 11, 2008 | 04:59 PM
amnesia's Avatar
Default RE: CCT Question
Just stick the key in and wind it all the way to retract the cct lifter and lock it with the key.
This is a great opportunity for you to play with the thing and see how it works! It can be released and rewound many times without any problem.
Old Mar 11, 2008 | 05:01 PM
F4iFreak's Avatar
Whew thats good news. I wasnt looking foward to dropping another 60 bux on one.
Old Mar 11, 2008 | 05:55 PM
TBFGhost's Avatar
If you can, tack weld the tip to the shaft....that is the main reason CCTLs tend to make noise....
Old Mar 12, 2008 | 09:07 AM
Tahoe SC's Avatar
psss....i can't remember who came up with the welding the tip thing but dude...if you're going to do it make sure that ****e never ever falls off because it goes straight to the motor....
Old Mar 12, 2008 | 07:53 PM
TBFGhost's Avatar
ORIGINAL: Tahoe SC
The weld? If it is welded anywhere near correct the weld will be stronger then the lifter itself....so yeah, if you are bad welder, you may want to check your weld and remove all excess to minimize anything falling off...
Old Mar 13, 2008 | 10:25 AM
Tahoe SC's Avatar
from what i remember, once you pull the pin out you have like 7 or 8 seconds to throw it.
did you throw it? muhahahhahah
Old Mar 13, 2008 | 04:12 PM
F4iFreak's Avatar
I threw it at his head afterwards
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
