CCT question
Old Jun 27, 2013 | 12:18 AM
Kopi Ko's Avatar
Default CCT question
Hi Guys
I plan to adjust valve clearance soon, but before that I need to gather information as much as possible.
I have a quick question regarding CCT. After finish with everything and reinstalling head cover etc, I need to remove the CCT holder tool.
Question: Do I just pull this out, or should I turn it slowly counterclockwise? Will it spring back and slap my cam chain?
Sorry for noob question.
Any help most appreciated. Thanks
Old Jun 27, 2013 | 02:01 AM
YunMing's Avatar
Just put it TDC then unscrew the bolts and pull it out
Old Jun 27, 2013 | 06:33 AM
rd91si's Avatar
I think he's talking about the tool that holds the spring from turning, yes you can
pull it out when your ready and it adjust automaticlly.
Old Jun 27, 2013 | 07:10 AM
Kopi Ko's Avatar
Yes I was talking about the stopper tool.
Thanks for the info!
Old Jun 28, 2013 | 06:51 PM
Kopi Ko's Avatar
Another question please.
I found this in work manual in relation to camshaft removal:
CAMSHAFT REMOVAL
Remove the cylinder head cover (page 8-4).
Avoid damaging the cam pulse generator while
removing the camshafts, remove the balt and cam
pulse generator from the cylinder head.
While searching other threads about valve clearance/adjustment, I never found this cam pulse generator being mentioned.
Do I really need to remove this part before I remove camshaft?
I don't want to do it if this step can be skipped.
Thanks for your advices
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
