CCT gasket leaking constantly
Hi all, has anyone else run into an issue with we persistent leak from the cct gasket? I’ve replaced the gasket multiple times, torqued it to spec, I’ve added sealant to the gasket, thread sealant to the bolts. The gasket surface is clean and appears flat but it continues to leak from the bottom bolt area.
