Broken Coolant Drain Bolt???? Help ASAP
Hey Guys,
So I was changing the coolant on my bike and I was tightening the coolant drain bolt and over tightened it and it snapped in half.
I dont have a torque wrench and I didn't think I was tightening it that much ut it snapped inside.
How do I get it out?
Is there any way to plug it till I get to bike shop?
Thanks guys
Thanks guys
if it broke off flush, your gonna have to drill it and use an ease-out. If ya got anything hanging out, vice-grips might help.
If you do drill it, keep a magnet next to it and collect all of the shavings, cleaning often, till you penetrate so you don't get any pushed into the system.
As far as plugging it, I think you should just wait till you repair it or you risk whatever you use as plugging material getting into the engine or popping out and losing all your coolant. That's bad for your engine and the neighbor's pets.
Tough break, might not have been your fault. Coulda' been the gorilla that was there before you weakened it.
As an aside, torque wrenches have gotten a lot cheaper than they used to be. Consider budgeting one in vs broke bolts and warped covers. Heck, put it on your amazon wish list for b-day or x-mas. ;-)
Well Im quite pissed I found out about the easy-out and grabbed one and when I was drilling I just short of getting it to catch so I drilled a little more and the stupid bit broke.
So know the bolts stuck with a drill bit in it.
So I think I am totally screwed now?
I think my 2 routes are see if someone can weld a nut on the end so it can be taken out which I dont think is the greatest idea inside the water pump or maybe get a new water pump or housing?
Either way Im pissed that a easy task turned into to such a hassle.
End Rant
End Rant
Well this may be a bit off topic as it doesnt relate to the broken bolt, but whenever I change the coolant in my bike, I just put the bike on stands, put a pan under the water pump, then remove the main hose coming from the radiator (disconnect it right there at the water pump so it drains the radiator and the pump) Its a hell of a lot easier that way and quicker too!
