Brembo 19rcs for the F4i?
Hi, does anyone know if the Brembo 19RCS(if not this then any other Brembo radial will fit?) would fit the F4i? I want to be sure there's enough clearance on full lock, i.e it shouldn't be touching the dash or the windscreen. I asked one of the dealers and they said it has not been tested on the f4i.
I had to run the throttle cables above the Mc so they touch the fairing at close to full lock, the lever clears no problem though, I was thinking when I first installed it and had it rotated up way too far.
Do know that the brembo won't really improve your braking power much, but it will give you a very linear feel.
