Brembo 19rcs for the F4i?
Hi, does anyone know if the Brembo 19RCS(if not this then any other Brembo radial will fit?) would fit the F4i? I want to be sure there's enough clearance on full lock, i.e it shouldn't be touching the dash or the windscreen. I asked one of the dealers and they said it has not been tested on the f4i.
I'm not sure about the brembo, but I put on a radial MC from an 08-12(I think) 600rr and it fit without much hassle. It's tight at full lock, but mines a track bike so I'm not worried about it.
Thank sjona2011. When you say tight, do you mean it touches the instrument cluster or the clearance is very less but doesn't touch?
Anyone else who used it on a road bike? |
I had to run the throttle cables above the Mc so they touch the fairing at close to full lock, the lever clears no problem though, I was thinking when I first installed it and had it rotated up way too far.
Do know that the brembo won't really improve your braking power much, but it will give you a very linear feel. |
Originally Posted by sjona2011
(Post 1318463)
