Braking problem !
Old Jan 1, 2013 | 09:50 PM
Gab's Avatar
Gab
Default Braking problem !
Hey guys, when im going at high speeds, around 100 KPH and more, when i press my front brake pretty hard, it feels like my brake is a bit jumping ?? do you have any ideas what could it be ? when im at lower speeds, I don't feel it. thanks alot
Sorry for my poor english ! im french hehe !
Gab
Old Jan 1, 2013 | 10:21 PM
Scott91370's Avatar
Warped rotor, old pads. Lift the front and spin the wheel while lightly holding the brake to see if you can hear the uneven wear.
Old Jan 2, 2013 | 12:17 AM
Gab's Avatar
Gab
Thanks for your fast answer ! I will do that tommorow morning. But may I ask : how will I know wether if its the pads or the disk that is causing the problem?
Old Jan 2, 2013 | 10:37 AM
boredandstroked's Avatar
It will be the rotor not the pad. Pad wear is dictated by the rotor.
Old Jan 2, 2013 | 09:46 PM
Gab's Avatar
Gab
just for the fun ! how much would be a new set of front discs
Old Jan 2, 2013 | 10:11 PM
CorruptFile's Avatar
June 2013 ROTM
Usually around $200 a side. You can get used ones for cheaper - but watch out for the really cheapo chinese ones on ebay, they often don't fit or aren't high quality.
Honestly, spend the money on good brakes, they might save your life.
You should upgrade the stuff that stops you before you upgrade the stuff that speeds you up.
Old Jan 3, 2013 | 08:36 AM
Ice_Cold's Avatar
Registered Users
Arashi rotors are fine, they use the same 420 stainless steel as high end rotors and the fit is perfect. Lots of poeple have had success with them if you google it.
Old Jan 3, 2013 | 08:39 PM
Gab's Avatar
Gab
Damn so that would be ~ 400 if the 2 disc did get a bit wavy ? Thats pretty expensive ! And thanks for all of your answers guys ! Really appreciated
Old Jan 3, 2013 | 09:31 PM
RudyGT's Avatar
i've been trying to find out if tightening the pincher bolts at the wrong time when mounting the front wheel, causeing the disc to be crooked, could cause this problem.
i assume the front wheel would vibrate like all hell at those high speeds too, but you did say 100kph for high speed, instead of say 130mph.
but i would focus at the problem at hand first and verify what is wrong
Kuroshio
Oct 22, 2012 08:03 PM
Bugkiller
May 2, 2012 11:06 AM
sony224422
Mar 27, 2012 08:17 PM
plivez
Nov 2, 2009 10:45 AM
jayking232003
Feb 9, 2007 04:57 AM
