brakes locking and wont release HELP!
Old Jan 18, 2009 | 01:36 PM
undercover_skank's Avatar
Default brakes locking and wont release HELP!
i changed my front master back to a stock one after i wrecked and broke the zx6r one. bled it and everything and it seamed like it worked good. took it for a test ride and it worked fine. next thing the front brakes slowly started engaging (by itself) and it locked up all the way. it was stuck. the only way for me to release it was to open up the bleeder valve to let the fluid out. and its free again. if i use the front brakes again itll slowly lock up again. whats the problem? i need help! thanks
Old Jan 18, 2009 | 05:43 PM
Default RE: brakes locking and wont release HELP!
no one!?!?!?!?
Old Jan 19, 2009 | 12:33 AM
playb0i's Avatar
is there any signs of dot4 fluid leaking? maybe the square cut seal in the caliper is not retracting back.
Old Jan 19, 2009 | 07:42 AM
krash's Avatar
I have had several things cause this on a rear brake. calipers sticking will cause it, bad MC seals will cause it, leaks in the line can cause it.
when you wrecked, did you do damage to the lines? did you replace them, did you replace the crush washers with new
you changed to "a" stock MC, do you know the history of the stock one?
Old Jan 19, 2009 | 11:08 AM
redzintimidator's Avatar
you probably need to rebuild your calipers or mc..either that or kink i nthe lines
Old Jan 20, 2009 | 11:40 AM
the lines look fine. i dont know the history of the stock master. just bought it from a guy online. theres no leak anywhere or anything. im gonna swap out the master this weekend and see where i get with that
Old Jan 20, 2009 | 12:21 PM
krash's Avatar
pretty good chance that MC is no good.
Old Jan 22, 2009 | 01:57 AM
finally go my hands on a master. same one i had when i wrecked. 08 zx6r. and it works fine now. i only rode it around the block so far and its just fine. ill ride tomorrow for a bit to be sure its all good. thanks guys!
jrbeau17
Oct 23, 2009 06:01 AM
DarkJuic3b0x
Apr 12, 2009 03:22 AM
camcovert
Feb 26, 2008 01:42 AM
Noam
Jul 18, 2007 03:46 PM
chpsk8er630
Feb 7, 2007 11:19 AM
