BRAKE ?s
Old Mar 23, 2006 | 03:01 PM
My02CBRF4i's Avatar
Default BRAKE ?s
how often should you replace the brake fluid in your bike ? and how do you know when your pads are bad ? can you tell by looking at them ?
Old Mar 23, 2006 | 04:21 PM
Tahoe SC's Avatar
Default RE: BRAKE ?s
yea mang...the pads have a groove on them. so if you don't see a groove on your pads, it's time to change them.
as far as fluid, bleed as often as you can with an F4i...why? will keep them from binding as a lot of gunk builds up around the pistons...so take the calipers off, remove pads, squeeze lever slightly to get pistons to extend, wipe away the gunk around them, use silicon brake grease or something aroud the pistons, push them back in and then pads and then install, torque, etc...
then you go with the bleeding. i would do so every 6K or so...
T
Black Rider
Nov 1, 2009 06:09 PM
6doubleohf3
Oct 25, 2009 09:01 AM
phillycbr
Sep 2, 2009 10:35 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
JJHUNSECKER
Sep 16, 2006 03:22 AM
