Brake help
Old Apr 14, 2008 | 06:17 PM
RooR Mast3r904's Avatar
Default Brake help
Ok well just put new tire back on and go to take a test ride and it is like the brake pads are to tight on the rotors. i tried pushing the pads back in and that didnt work any ideas????
Old Apr 14, 2008 | 07:12 PM
honda502's Avatar
Default RE: Brake help
Did you touch the rear brake pedal when the caliper was off?
Old Apr 14, 2008 | 07:47 PM
pashosr's Avatar
If your talking about the front then the same thing happened to me, it was like i had a squeak at one certain part when the wheel rotated. Mine took about 1000 miles to quiet down. I took mine back apart and tried it again with the same results. For some reason withthese rotors being drilled its almost like when youtake the pads out of theirhappy spot from the rotorthey need time tosettle back in.You could sand the pads and rotor(s)a little bit(more likescuffing) if it reallyannoyed you.
Old Apr 14, 2008 | 07:48 PM
RideHonda's Avatar
There is always going to be some drag in the brakes, thats normal. If they are tighter then a drag, like Honda502 asked did you hit the brake while the rotor was off the bike? If so you need to take apart the caliper and rebuilt it.
Old Apr 15, 2008 | 11:09 AM
no i dont think i hit the brake i am going to take the tire off soon and start new
Old Apr 15, 2008 | 01:06 PM
Jaybird180's Avatar
Take your old set of pads and push the pistons back.
Black Rider
Nov 1, 2009 06:09 PM
6doubleohf3
Oct 25, 2009 09:01 AM
phillycbr
Sep 2, 2009 10:35 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
JJHUNSECKER
Sep 16, 2006 03:22 AM
