Both Headlights on at the same time?
Old Dec 28, 2009 | 03:47 PM
  #21
ddaren's Avatar
Why don't you be like me and aim your high beams down? Then you can run both sides during day and night without blinding anyone. Only problem is you lose you high beams. I never did use em before anyway so it's not a big deal for me
Old Dec 29, 2009 | 01:49 PM
  #22
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Originally Posted by knonfs
Yes it is. There is no other way of having dual lights without having the hi beams on.
Sure there is.
If you want to get rid of the single light low beam look, you have 3 options (besides leaving the high beam on).
1.Wire in a device to run the high beam at 40% power when the low beam is on and at 100% when the high beam is on.
http://www.600rr.net/vb/showthread.php?t=63693
2.Swap out to H4 bulbs and wire in a relay to run the new bulbs.
http://www.600rr.net/vb/showthread.p...light=bi+xenon
http://cbrworld.net/forums/1/35094/ShowThread.aspx
3.If you want to use HIDs, you will have to do a HID projector retrofit.
http://www.1000rr.net/forums/showthread.php?t=60297
Old Dec 29, 2009 | 04:15 PM
  #23
knonfs's Avatar
Originally Posted by RoadiJeff
Sure there is.
I stand corrected
With that said, I still think is a waste of time, and those $60 will get you a MUCH better visibility with a HID kit...
Old Dec 29, 2009 | 04:32 PM
  #24
MC_spirited's Avatar
Is it possible to replace the high beam reflector for a lo beam reflector, giving you two low beams? My cousin was interested in this but it seems like a big pain to halfass solve what is (for him) a aestetic gripe ( doesn't like that both lights don't look the same oncoming).
Old Dec 29, 2009 | 05:28 PM
  #25
xjoewhitex's Avatar
As far as I know they are both the same just pointed in different directions (Up-Down) So all you would have to do is adjust the bright side down to match the low beam?
Old Dec 30, 2009 | 04:51 PM
  #26
Maddawg777's Avatar
I know the light fixtures have an adjustment on them. Do I just use the adjustment or is there more to it???? Thanks!
Old Dec 30, 2009 | 04:56 PM
  #27
xjoewhitex's Avatar
Thats it.. as long as there are two adjustments for each housing and not one for the both. You will be able to adjust them to the same direction. (you will lose your hi beam tho) So do this only if you ride in the day time only.
Old Dec 31, 2009 | 12:42 PM
  #28
skoobydoobie's Avatar
They are different. Take a good look at the reflectors you will see the difference.
Old Jan 1, 2010 | 01:05 AM
  #29
xjoewhitex's Avatar
Well I was just throwing out ideas.. I never looked at mine because I don't mind running one side.
Old Jan 1, 2010 | 07:09 AM
  #30
PlayfulGod's Avatar
smack him upside the head n tell em to grow the f*ck up n quit bitching.
And FYI running brights during the day isnt a safe thing to do
