Blinker on when Braking?
Old Oct 11, 2008 | 08:19 PM
my_honda's Avatar
Default Blinker on when Braking?
My bike has a HotBodies undertail kit. Previous ownered installed it. For some reason, when I press the brake, the left blinker on the guage comes on. It does not flash, it just turns on and then off when I release the brake. I'm assuming it's a wiring problem. I dont have the instructions, so does anyone have a clue where I should start looking?
Old Oct 11, 2008 | 10:50 PM
bakesf4i's Avatar
Default RE: Blinker on when Braking?
It sounds like one of the brake wires is touching or connected to your turn signal wire. So check either the blue or the orange wire (forget which one is L and R)coming from the bike and see if its touching anything else. If not then start disconnecting wires to figure out what goes where.
Old Oct 13, 2008 | 11:32 AM
MidnightG35X's Avatar
Does it the blinker turn fully on or does it just slightly turn on? Also, are the bulbs regular or LED's? Creating a ground loop is pretty common. One thing to try is to use separate grounds for the blinkers and the brake wires.
Kuroshio
Oct 22, 2012 08:03 PM
sony224422
Mar 27, 2012 08:17 PM
2H company
Nov 29, 2009 07:28 AM
plivez
Nov 2, 2009 10:45 AM
LlanoSV
May 12, 2007 10:04 AM
