wont start. Ok i'm sure u all now when u turn the key the speedo and tach move and there is a high pitched noise(fuel pump priming?) well mine does all that except the high pitched noise. Any help will be welcomed.
are the turn signals and headlight on the guages staying on? if so try pulling your headlight fuse out and listen to see if the fuel pump primes. if im all that happens come back and let me know
Went out there to my garage last night and everything had stopped working. the harness on the front of the bike behind the front fairng had come a liltle loose. easy fix thank god
