My bikes not starting right away anymore!
Old Apr 21, 2012 | 06:30 PM
WangDangger's Avatar
Post My bikes not starting right away anymore!
today my bikes didnt start right away it even took two tries at a gas station its a 2008 600rr w/6000 miles, is it my spark plugs? HELP
Old Apr 21, 2012 | 09:13 PM
Dirtrider009's Avatar
Can you be a little more detailed?
What do you mean it didnt start right away? did itt spit and sputter, did you have to crank it for a minute?
what does two tries mean? just tapping the starter or again cranking it. when it did start did it start hard and idle rough or purr like a kitten.
Old Apr 21, 2012 | 09:38 PM
CJardine's Avatar
Track junkie & modaholic
charge your battery. start there
Old Apr 21, 2012 | 10:07 PM
ive been riding for about an hour stoped to talk to a guy with another cbr at a gas station the bike temp was at 104 degrees when i turned it off. when i tried to start it i held the starter down for a few seconds but couldnt get it to turn over, there was no loss of power or anything every thing sounded normal just wouldt crank so i tried again for a few seconds and then it finaly cranked. she ran fine after that ive been going out every hour and trying to crank it and shes starting normal now almost right away but i want to try to get it fixed case this happens again kinda worried you know the bikes still new!
Old Apr 22, 2012 | 01:48 AM
RedBaron's Avatar
2 tries at starting is nothing to wory about if it only happened the one time. LOL
Old Apr 22, 2012 | 02:48 AM
CJardine's Avatar
since you've been starting it up without riding it a lot lately I would recommend sticking it on a trickle charger for a night just to top off.
Old Apr 22, 2012 | 04:22 AM
RedBaron's Avatar
Do you mean nothing happens when you hit the start button? <--Battery
Or it turns over but doesn't start?
Old Apr 22, 2012 | 07:12 PM
no it turned over just wouldnt crank but shes doing fine now maybe im just being peranoid! yea i think im gona get a trickle charger any way my dad recommended one also. i had my bike serviced at 5k miles and they said my battery had lost a lil life but was still in the good range!
Old Apr 22, 2012 | 10:41 PM
For future reference, turning over and cranking are the same.
Old Apr 23, 2012 | 03:02 AM
KeysRider3's Avatar
I used to have a VW with the same symptom. Turned out there was moisture in the fuel. The high heat of the engine (after shut-down) caused the moisture to displace the fuel, creating a "gap" in the fuel supply. It was not happy, and would not start until it got the amount of fuel it wanted! Try some fuel system conditioner for the next couple tanks-full of fuel.
