Bike wont start
Old Oct 17, 2022 | 01:28 PM
bikesrus98's Avatar
Question Bike wont start
When I turn the key my cluster comes on but when I hit my starter button nothing happens. It doesn't even click like it's even attempting to start. Any ideas as to why this is happening?
Old Oct 17, 2022 | 04:15 PM
dannoxyz's Avatar
Hi and welcome!
What model & year bike do you have?
1. measure battery-voltage with everything OFF. Volts = ???
2. measure battery-voltage during cranking (or just pushing start-buttong). Volts = ???
3. if your bike has BAS, measure its output at ECM connector. Compare values with those given in manual.
Old Oct 18, 2022 | 09:58 AM
Scott91370's Avatar
I've got to ask the obvious.
Is the kill (run) switch on or off?
Are you pulling in the clutch?
Do you hear the fuel pump prime?
Old Oct 18, 2022 | 10:46 AM
bikesrus98's Avatar
Its a 2000 600 cbr f4. With the bike off its shows around 12.2 and during crank it's around 10.3
Old Oct 18, 2022 | 10:48 AM
bikesrus98's Avatar
Kill switch is off. Pulled the clutch in. Don't hear the fuel pump prime at all. If I press the button enough time sometimes I get lucky and it comes on but very rarely.
Old Oct 18, 2022 | 11:52 AM
dannoxyz's Avatar
Put battery on trickle-charger overnight. Want 13.8v fresh off charger and no less than 11v when cranking. Otherwise not enough voltage to run ECU and fire sparks.
Also use some electronics cleaner like Deoxit to clean contacts in ignition-switch, kill switch and start-button.
Old Oct 18, 2022 | 12:10 PM
bikesrus98's Avatar
This is with trickle charge already being done. So chances are need a new battery?
Old Oct 19, 2022 | 07:59 AM
It's certainly looking that way, you could try to jump it from another battery to make sure, if using a car prob best not to have the car running tho.
Old Oct 19, 2022 | 04:18 PM
On a 2000 F4, there is no fuel pump prime to listen for, it's carbureted, not FI. Nothing to worry about there.
Rodd
Aug 12, 2021 08:11 PM
RekTek
Jun 5, 2014 01:52 PM
05CBR600F4i
Feb 16, 2011 05:31 PM
twiceborn00
Aug 29, 2009 11:21 AM
ishboo22
Apr 16, 2009 10:12 PM
