Bike wont start
When I turn the key my cluster comes on but when I hit my starter button nothing happens. It doesn't even click like it's even attempting to start. Any ideas as to why this is happening?
Hi and welcome!
What model & year bike do you have?
1. measure battery-voltage with everything OFF. Volts = ???
2. measure battery-voltage during cranking (or just pushing start-buttong). Volts = ???
3. if your bike has BAS, measure its output at ECM connector. Compare values with those given in manual.
Put battery on trickle-charger overnight. Want 13.8v fresh off charger and no less than 11v when cranking. Otherwise not enough voltage to run ECU and fire sparks.
Also use some electronics cleaner like Deoxit to clean contacts in ignition-switch, kill switch and start-button.
