best way to fit frame sliders?
white knight: Read, and revise your statement: https://cbrforum.com/forum/f4i-main-forum-11/dropped-my-bike-morning-118621/
Laser method: take fairing off, mount laser and point at center of bolt. Put fairing back on, drill hole, mount slider, done.
I took the side fairings off. Put the frameslider "bolt" in the hole(without the slider). Slide the fairing back on and pressed the fairing against that bolt and it made an indent in the inside foam, that would be the center. Drilled a small hole where center is. Flipped it around to the front of the side fairing and then drilled a 2" hole with a holesaw. Make sure you put masking tape first where your going to holesaw it out, will keep paint from splintering and tearing up the edges.
Listen to this man, and save yourself the "laser" trouble. The above method is guaranteed to work everytime!
If you're going to go this route line up at lease three combinations of at least two differant fairing holes and pick a point in the center of the three differant marks. If you only do it once your hole will very likely be off center! That is why I recommend the laser method.
