Battery
Old Feb 9, 2010 | 07:55 AM
Drew51's Avatar
Default Battery
I know that this is a nube question but I just got my bike yesterday and need to know how to get the battery out of it so I can give it a charge.
Drew
Old Feb 9, 2010 | 08:12 AM
chetman7's Avatar
Un
screw the 2 bolts under the main seet and pyull out the seat
Old Feb 9, 2010 | 08:52 AM
fairman86's Avatar
if you have a split seat 01-03 then;
At the rear corners of your seat, there are 2 bolts, push the foam out of your way and shove a 10mm socket with an extention on it and remove both bolts, then your seat will come right off. flop your computer out of the way, and you should be starring at your battery box, there will be 2 "pin" type fasteners, pull the centre of the "pin" on both of them and they will click up releasing the lid. now the lid is hinged so it's a pain to keep open, while unscrewing the battery posts. Posts should be a #3 phillips screwdriver to undo them. cheers
Old Feb 9, 2010 | 10:56 AM
Berto's Avatar
Drew
Ummm...get a tender and charge it in place.
I have an onbike plug (attached to the subframe) just for this purpose. Same plug on all my bikes.
--Paul
estate4life
Dec 4, 2012 11:08 PM
jharbinson
Dec 31, 2009 09:23 AM
xander071584
Dec 24, 2008 01:45 PM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
