Bar End Problem
Old Apr 14, 2008 | 05:21 PM
Allamericantc's Avatar
Default Bar End Problem
Hey guys. I accidentally knocked the bike over in the garage. Everything is okay except for the left bar end. It actually broke off inside the handle bar. What do I do? How do I get the existing piece out of the handlebar and can you buy a new handlebar bar end set up? Thanks for any help!
Old Apr 14, 2008 | 05:23 PM
Aken's Avatar
July 2008 ROTM
Default RE: Bar End Problem
Dremel a notch into the bolt, then use a flathead screwdriver to remove it. Replace the bar end if it was the only thing damaged, and you're good to go!
Old Apr 14, 2008 | 05:26 PM
ampfp's Avatar
Many times the bar weight will break (this is the piece the bar end screws into). It's a rod with rubber grommets at two ends, which hold it internally against the handlebar tube. So you have to pull against the friction of these rubber grommets somehow if you need to replace the bar weight. Worst case, cut the grip and there's a hole underneath that _might_ help getting the bar weight out.
was a PITA when I did it.
Where do I buy a new bar end set up? I see the bar end ***** for sale everywhere but I need the whole thing inside the bar also
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
