anyone use a wideband commander?
Old Jun 21, 2014 | 04:58 PM
RudyGT's Avatar
Default anyone use a wideband commander?
so my bike is bogging at full throttle in the mid RPM's, not sure if i just didnt notice after installing another pipe, but i did notice after a quick turn throttle mod.
and well, wideband commander 2's are going to be the same price as a dyno tune.
f4i's have huge ram air intakes and from what i was reading the kawi 600's were beating other bikes in the late 90's due to ram air adding 6hp's or more.
so im thinking it would be better since hardly any dyno's adjust wind for speed, to go the wideband commander route.
does anyone know if it tracks, throttle position, rpm's and a/f ratio? and do you notice a difference in a/f from 3rd gear 10krpm WOT and 6th gear 10krpm WOT?
^^ of course not using a PC5, where you can adjust a/f per gear. which btw is the only PC available for the f4i now..
edit: also where does one attach the bung? i have a 16mm on my yoshi pipe but need an 18mm so im forced to drill and weld i guess.
let me also add when i release the throttle from WOT it has more power.
Old Jun 23, 2014 | 11:43 AM
RudyGT's Avatar
just got off the phone with dynojet, and they were saying the wideband commander 2 will only log TPS and RPM's with an interfaceable device such as the PCV not pc3usb.
and that it can only datalog with the LCD and gig memory stick. sounds like a serious design flaw it doesnt allow for those inputs.
Old Jun 30, 2014 | 12:40 AM
Congee's Avatar
I was wondering the same thing a few weeks ago before getting a custom Dyno tune done using my PCIII USB. While getting my Dyno tune, I asked my tuner about the fact that there's a lot of elevation changes in the northwest and whether a wideband sensor + PCV would make a difference.
He said the performance differences would be negligible and that I'd have to relocate to a state that had major elevation difference to notice any change in performance.
sjona2011
Sep 23, 2013 07:26 AM
joe-4422
Apr 7, 2009 09:47 AM
Camman
Dec 21, 2008 11:00 AM
maxwell139
May 16, 2006 01:30 AM
CMHGUY
Apr 7, 2006 05:32 PM
