Alternative to pricey rearsets..
Old Jun 16, 2013 | 02:01 PM
Gnarly 928's Avatar
Default Alternative to pricey rearsets..
I can't take credit for this idea, which I saw somewhere in the past. Here is my own solution.
I was touching my boots down frequently at my first track outing on my '02 F4i, despite having racetech-ed the fork springs and raised the rear ride height with shims at the shock mount. Despite getting clear out on the toes of my boots on the pegs, I was wearing into the sliders and the soles with the stock foot pegs.
With just a bit of appx. 3/8" thick aluminum stock and some metric cap screws from the local hardware I saved a bunch of bucks and ended up getting my pegs about 1 1/8 back and 1 1/2 higher up. Pretty simple, too. I did make a false start, trying to go too long with the bottom plate and trying to use shims, washers and fancy 'Z-brackets'...Second time around, everything works slick...
I used one longer cap screw where the stock bracket attaches through a small spacer I fabricated from 3/8" aluminum plate. This goes behind the upper bracket mount hole to match with the link I used to rotate the whole footpeg assembly upward and move the lower corner rearward.
I also put a nylock nut behind the link, threading it onto the original peg mounting bolt as it protrudes through my 'rearset' plate.
Same thing on the brake side. The shifter linkage rod could be a little longer...it is a bit 'thin' on threads as is...I will get to that.
Old Jun 16, 2013 | 02:51 PM
boredandstroked's Avatar
Honda CBR F4 F4i Silver Rear Set Riser Plates Rearset
Same idea as yours. They come with an extender for the shift rod, reasonable price too.
Old Jun 16, 2013 | 03:01 PM
Gnarly 928's Avatar
Maybe that's where I saw the idea......Ten times as much as I spent, though, there on Ebay...... you do get the shift rod extender....
I am now looking for a shift 'lever' to fit onto the stock spline...one that extends outward a little more and is slightly longer than the original ...so I can swap over to GP shift pattern.
Anyone know of one that is configured like that?
Old Jun 16, 2013 | 03:13 PM
CJardine's Avatar
Track junkie & modaholic
Well I have pricy rearsets and they are GP shift, but you might be able to addapt the woodcraft ones to work or find some adjustable shift levers. You might be able to do it with just a longer shift rod though.
Old Jun 17, 2013 | 10:33 AM
There was a thread recently about using a CRF lever or something similar to turn stockers into GP shift, might help ya.
jjbtao
How-To: Mechanical
52
May 10, 2012 08:26 PM
land_warrior.rus
Jan 11, 2010 12:06 PM
speedra500
Jan 31, 2007 07:25 PM
NINE2NINE
Dec 22, 2005 01:25 AM
