AIR DUCT QUESTION
Old Jan 13, 2007 | 04:57 PM
shraz's Avatar
Default AIR DUCT QUESTION
Is the airduct thing on top attach with a clip or what? Do I just pull it and it will detach from the main air duct? I try pullin w/ no luck
Old Jan 13, 2007 | 11:01 PM
Tahoe SC's Avatar
Default RE: AIR DUCT QUESTION
which part of the air duct mang?
the actual rubber pieces that connect the air box to the plastic ram air/resonator piece? that one is not connected with anything, but may be glued at the air box portion.
Old Jan 15, 2007 | 04:10 AM
shraz's Avatar
no, not the one that connects to the airbox
the one that is a very small part on top of the air duct and has a little screw clip
Old Jan 15, 2007 | 01:34 PM
Tahoe SC's Avatar
the resonator??? i think it's just held up on by plastic bolts...but i can't be sure.
Old Jan 15, 2007 | 02:34 PM
KidCr3nshaw's Avatar
I think I understand you...
If I do, you've just got to grab that beotch and pull on it. Make sure all the screws are out and just work that beotch off. The F3 is similar, you just gotta torque on it. It seemed to me that I was gonna break something the first time I removed mine too...
Just double check that all bolts and screws are removed and pull that beotch!
Old Jan 16, 2007 | 06:22 AM
shraz's Avatar
cool thanks
but I decided didn't need to remove it [&:]
Mr_CBR600RR
Oct 7, 2009 03:46 PM
itgbudeev
Dec 22, 2007 03:11 PM
Bobinbaghdad
Apr 19, 2007 08:05 PM
Roundman
Mar 6, 2007 02:47 AM
Morta
Dec 27, 2006 06:55 PM
