AIR DUCT QUESTION
Is the airduct thing on top attach with a clip or what? Do I just pull it and it will detach from the main air duct? I try pullin w/ no luck
RE: AIR DUCT QUESTION
which part of the air duct mang?
the actual rubber pieces that connect the air box to the plastic ram air/resonator piece? that one is not connected with anything, but may be glued at the air box portion. |
no, not the one that connects to the airbox the one that is a very small part on top of the air duct and has a little screw clip |
the resonator??? i think it's just held up on by plastic bolts...but i can't be sure.
I think I understand you...
If I do, you've just got to grab that beotch and pull on it. Make sure all the screws are out and just work that beotch off. The F3 is similar, you just gotta torque on it. It seemed to me that I was gonna break something the first time I removed mine too... Just double check that all bolts and screws are removed and pull that beotch! |
cool thanks
but I decided didn't need to remove it [&:] |
