Adjusting throttle play...
Minor adjustment can be obtained at the handle bar using the two bolts where the cables tubes attach. If you need further adjusting, then you have to do it at the throttle bodies, under the airbox. Same principle as adjusting the clutch cable; loosening the bolts will lessen slack/freeplay.
