Adjusting throttle play...
Old Sep 4, 2009 | 07:39 PM
Shawn05F4i's Avatar
Default Adjusting throttle play...
Off the bottom it seems like my throttle has gotten loose...too much play for me.Is it easy to adjust?I've never done it before.
Old Sep 5, 2009 | 07:55 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Minor adjustment can be obtained at the handle bar using the two bolts where the cables tubes attach. If you need further adjusting, then you have to do it at the throttle bodies, under the airbox. Same principle as adjusting the clutch cable; loosening the bolts will lessen slack/freeplay.
G-ShocK
Aug 26, 2009 04:19 PM
travisb
Nov 28, 2007 03:37 PM
CBRYDR
Sep 20, 2007 09:20 AM
britman
Sep 18, 2006 09:54 AM
fullmetalf4i
Jan 24, 2006 11:04 PM
