2006 Air Filter
It's real easy. You don't need to completely remove anything, just loosen and disconnect a few things.
The air duct covers - Remove the #5 allen screw and then pop out the tab from the rubber grommet and pull it away.
Remove the seat.
The Tank- Remove the front 2 8mm bolts, be careful there are two metal sleeves that will fall out once you lift the tank. Remove the 2 12mm bolts on the back of the tank. From here you can lift the front of the tank vertical and prop the tank up.
The Air box- Remove about 12 8mm bolts around the perimeter and one in the center.
Pull out the old filter and install your K&N. Put everything back together in reverse order.
Good Luck Hope this helps.
Remove the seat.
Here's an exploded diagram...
HONDA OF TULSA 2006 Honda Street Bike CBR600F4i (EXCEPT CALIF) Parts List
Ern
Ern
