2003 F4i MYSTERY...NEED HELP
Old Jul 6, 2007 | 05:53 PM
birdstrike's Avatar
Default RE: 2003 F4i MYSTERY...NEED HELP
When you jump the plug you're fuel pump works, problem solved, its the plug
Old Jul 6, 2007 | 06:32 PM
BabyComfortF4i's Avatar
check the green wire in your wire harness that goes to the headlights. usually that pin comes out
Old Jul 7, 2007 | 02:52 AM
sonic13's Avatar
well, i think i found the problem...took off my ignition switch and loosened the bottom and i found our that a resistor or diode is blown...could this be it? does anyone know what that does?
Old Jul 7, 2007 | 05:56 PM
Jaybird180's Avatar
Diodes are like a 1-way flow regulator for electricity. Resistors, limit current flow.
Old Jul 7, 2007 | 11:40 PM
sonic13's Avatar
is this why my fuel pump doesn't prime?
Old Jul 8, 2007 | 09:27 PM
sonic13's Avatar
replaced the diode but still same problem...im stuck. checked for trouble codes again but get no blinks...ecm maybe?
Old Jul 8, 2007 | 09:45 PM
thirdgenlxi's Avatar
Ironmang
Are both your headlights coming on? Or are both turn signal indicators staying lit on the cluster?
Old Jul 9, 2007 | 01:15 AM
sonic13's Avatar
nope...all lights work fine. low beam, high beam, front and rear signals.
Old Jul 9, 2007 | 03:12 PM
Jaybird180's Avatar
Dunno, but IIRC a blown diode will open the circuit and a blown resistor will give you infinite resistance (drain battery, no juice anywhere else) until is burns itself out and give a short circuit (break in circuit).
Old Jul 9, 2007 | 11:53 PM
sonic13's Avatar
yea...supposedly its for anti-theft purposes. bought a new one from radio shack and replaced it. cheaper than buying a new ignition.
