2002 f4i battery/charging problem
Old 03-09-2014, 03:23 PM
Raybuck's Avatar
New Member
Default 2002 f4i battery/charging problem
Hey everyone now to forum ive have a problem with my f4i. The bike when running at idle the turn signal lights will gradually dim and if you rev it the light brighten. Also if you rev it a lot real quick it will die and have slight issues starting, just give it gas and it starts. I checked the battery with it not turned on and it is 12.7v, running at idle and is around 12.3-12.5v and if you rev to 3000 rpms it will rise to 14.7v.
I've had this problem last year and replaced the r/r and fixed it, just got lucky didn't check anything. Since i checked a few things this time I was wanting to double check before i buy a new part.
Thanks for any replies guys and gals.
Old 03-09-2014, 04:06 PM
Raybuck's Avatar
New Member
also using handy manual i found the stator plug and got readings of about .5 ohm between all the wires
Old 03-10-2014, 10:52 AM
svek's Avatar
Since you have a multimeter, follow this flow chart step by step. This will rule out loose connections, the stator and the RR
http://www.electrosport.com/technica...ng-diagram.pdf
hmm
02-05-2015 12:10 AM
f4i.fft2
08-14-2009 07:40 PM
njdjh2o
04-11-2008 07:20 PM
dachamp312
01-20-2008 08:47 AM
weeble1
05-10-2006 02:35 AM
Quick Reply: 2002 f4i battery/charging problem
