2001 F4i Turnsignal and Tail light issues, PICS included
Old May 28, 2008 | 01:35 AM
sig239's Avatar
Default 2001 F4i Turnsignal and Tail light issues, PICS included
Hello all,
Recently picked up a 2001 F4i that has some minor wiring issues. The turn signals do not work and when you select a right turn the emergency flashes come on? The tail light does not work either. I have found this mess of wiring that is probably responsible for all this and was wondering if anybody could give me some input. If someone could take a picture of their current wiring that would help out also.
Thanks
Old May 28, 2008 | 03:41 AM
whtan20's Avatar
Default RE: 2001 F4i Turnsignal and Tail light issues, PICS included
Is this a stock tail light? The blue, white, and orange connectors should be plugged to your lights.
Old May 28, 2008 | 08:20 AM
sig239's Avatar
im not sure, completly new to this bike. Here is another pic of the tail light. Thanks again for any additional input, really need some help here.
Old May 29, 2008 | 11:15 AM
Etalono61's Avatar
You're problem is that whoever had the bike before ripped out the alarm, or theundertailthat was installed on it. the wires are stripped so u either need to buy new connectors or simply cut out the original ones and splice the correct wires together, once i get home i can help u out with what wires go where. since i dont have manual at work.ill repost latertoday
Old May 29, 2008 | 11:32 AM
Aken's Avatar
July 2008 ROTM
Yeah, looks like the wires with the red connectors went to an undertail or alarm or something. Your stock signals would plug into the orange and green connectors. You can either cut those connectors off and re-splice everything yourself, or order a new set. The wiring is pretty simple for the back - you should only have two turn signal wires, power and ground. The tail light bulbs should have their own harness and should be fine as long as you aren't having any issues with them.
Old May 29, 2008 | 03:51 PM
sig239's Avatar
worked on it some last night and made some progress. Seems like the previous owner tried to do the trailor convertor integrator and failed horribly. Starting cleaning everything up and was running everything backwards until finding out that all solid green wires are grounds. Picked up some turn signals today during lunch so everything should be back to normal tonight. appreciate the help everyone.
Old May 29, 2008 | 06:03 PM
axsys's Avatar
do you have a service manual? if so, the wiring diagram in it should help you out with what colors do what from the harness back there
Old May 30, 2008 | 11:36 AM
Etalono61's Avatar
yeah i looked for the diag that i had but it seemed to have disappeared
schooobs
Feb 6, 2011 06:48 PM
darryle
Feb 9, 2010 05:30 PM
Dr.Fingers
Jul 16, 2009 05:12 AM
alekinci
Apr 3, 2008 09:54 PM
CBR1000
TRG Coating
Mar 24, 2008 10:35 PM
