02 F4i Restoration Project
I recently picked up an 02 F4i...miles were low, but aesthetically it definitely needs some work. The owner told me he dropped it a couple of times so there are some dings and dents, including a big one on the left side of the gas tank. While it isn't terrible looking, its far from perfect. So I made this thread to give you guys an overview of the progress. Any input or advice would be much appreciated.
The windscreen is missing, front cowl is cracked, one mirror missing, and scratches on the left side fairing and scratched stator cap.
Parts are on their way.
Front cowl
Dent in gas tank.
Front cowl
Dent in gas tank.
Def a good candidate for some TLC...a solid base to work w/.
Windscreens are cheap on eb*y...& perhaps someone here has a spare for you for cheap, same for the mirror & stator cover. You can get a front cowl fairly inexpensively from Delkevic, motorcyclefairingrus, etc. As for the tank, most likely replacement would be cheaper than repair, that is - unless you are an expert & can do it yourself.
Good luck w/ everything. Look forward to seeing your progress.
