01 600 f4i kicking 2nd gearw
Old Dec 4, 2018 | 07:52 PM
Junior1540's Avatar
Default 01 600 f4i kicking 2nd gearw
I have 01 600 f4i kicks me out of second gear when I give throttle. Only second gear every other gear is fine suggestions?
Old Dec 13, 2018 | 04:07 PM
boredandstroked's Avatar
Take bike apart and inspect transmission components.
Old Dec 14, 2018 | 08:47 PM
Junior1540's Avatar
could stock chain and sprockets cause this? My chain is tight then when I turn tire goes back to normal which leads me to believe that chain is shot.
Old Dec 15, 2018 | 11:12 AM
ceebeeaarguy's Avatar
No the chain won't cause this. Misaligned chain/sprocket may sometimes, but that should affect all gears. Tight spots on a chain is usually due to not lubing it frequently resulting in links dying. Usually on sportsbikes it's the 2nd gear which goes likely because people gun it in 2nd to 'enjoy' the acceleration , wheelies etc. Do you or did previous owner identify as hooligan rider ?
Old Dec 15, 2018 | 12:04 PM
Junior1540's Avatar
Not me gotta be former owner so I'm gonna have to pull motor and dig deep to fix this one?
Old Dec 15, 2018 | 06:37 PM
Yes, no other way I am afraid mate. You'd have to drop the motor and poll the transmission out to see what needs to be renewed.
Here. some threads to get you going
https://cbrforum.com/forum/general-t...nd-gear-68516/
https://www.600rr.net/vb/62-troubles...mping-out.html
Ton of info on this forum itself. These are the kind of jobs which require time and patience but at the same time most financially rewarding as the biggest part of the bill if you get it done in a garage is labour. Easily approaching high $$$. So bring your manual out and get wrenching.
Old Dec 15, 2018 | 07:18 PM
Junior1540's Avatar
Thanks for all the help and info. I'll get at it!
Old Dec 20, 2018 | 02:53 PM
Sounds like your chain is toast, but no this is usually caused by a bad shift fork inside the trans.
Old Feb 26, 2019 | 09:22 PM
Junior1540's Avatar
Default Its been a while since last post but would this be the cause of 2nd gear kicking
Gouge on shift drum
Old Feb 27, 2019 | 01:10 AM
CaBaRet's Avatar
Probably so, looks like Fork has cut across that corner , best to take it out and check forks too
Robert Peczkowski
Nov 21, 2014 07:46 PM
SNOWMAN
Feb 8, 2008 07:24 AM
MarkR
Apr 27, 2007 11:07 PM
JZHALES
Apr 24, 2007 04:36 AM
