Speedo swap?
Old Apr 14, 2013 | 05:18 PM
Firesnake's Avatar
Default Speedo swap?
Good day everyone
I'm building a streetfighter of my F2 and i'm looking around for a simple digital speed to instal, but I'm not so experienced with mechanical stuff or electrical for that mater, So i was wonder if something like this would be easy to instal? i have the haynes manual
DIGITAL-COCKPIT - Louis - Motorrad & Freizeit
And maybe anyone know of a "how to" guide for a speedo swap?
- Firesnake
Old Apr 21, 2013 | 09:27 AM
MadHattr059's Avatar
Double check your research, I'm pretty sure the F2 uses a mechanical cable off the front hub. So it's gonna be trickier than a newer model, if it's possible at all.
Hopefully someone else can give a more authoritative answer.
Ern
Old Apr 23, 2013 | 08:08 AM
gtcole's Avatar
Welcome Crew
The f2 does indeed use a mechanical speedo, cable driven Speedo. I can't get that webpage to translate but have seen other digital speedos with a hall effect conversion for the pick up signal. I would call the support and inquire about the reference signal used. Give them your bike info and they should be able to tell you if it will work and how.
Old Apr 23, 2013 | 11:21 PM
holyniht's Avatar
I have the digital speedo off of the f4I however but i havent put it on yet... you have to get a sprocket cover that has the ability to pull ur actual speed and feed it into the respect wires for the speedo ... i dont remember the specifics but i remember reading a write up on this forum.
Old Apr 24, 2013 | 07:13 AM
R3define's Avatar
Your going to need a few things. I also know you need a speedohealer as the translation from the mechanical speedo to the digital doesn't just work.
Here's the thread your looking for. Should be pretty similar.
https://cbrforum.com/forum/f2-tech-9...rite-up-91012/
Emmanuel Lind Chrisalos
Sep 26, 2013 06:58 AM
jonnolad
Oct 6, 2012 05:41 AM
hot83chevy
F2 Tech
Aug 12, 2010 02:14 AM
Bringingf2bak
F2 Tech
Apr 23, 2010 03:22 PM
pie656
Sep 22, 2008 10:40 AM
