Pilot/Slow Jet question....
Old Jul 1, 2010 | 07:43 PM
DopeBoy239's Avatar
Default Pilot/Slow Jet question....
I am cleaning my carb and when I went to clean the slow jets I noticed the hole does not go all the way through. Is this normal? All four of them are like that so I'm guessing it's supposed to be like that but how does fuel get through?
Old Jul 1, 2010 | 09:30 PM
cbr900racer77's Avatar
Did you stick the long tip of carb cleaner can in there and spray? If everything is clean, cleaner should run out tiny hole in front of butterfly. It'll also run out fuel screw holes if they are removed. It's got to be there or you're cleaning some "mystery" part LOL.
Old Jul 1, 2010 | 11:39 PM
jk72180's Avatar
the holes are tiny i used a strand of wire out an 18 guage wire and it barely fits thru but you shoud be able to see light thru them.
Old Jul 2, 2010 | 12:51 AM
C Average's Avatar
I foudn that grocery store produce twist ties are the best. I just soak them so the paper comes off easy.
Old Jul 3, 2010 | 09:14 AM
DopeBoy239's Avatar
I can see through them now. Must have been bad lighting. Also, the wire from a loaf of bread will not fit.
Old Jul 4, 2010 | 01:26 PM
Be VERY easy using any type of metal strands to clean them. They are very soft and even the slightest mark on them will affect their flow.
hamlin6
Apr 6, 2013 03:01 PM
Tort93f2
F2 Tech
May 15, 2012 03:23 PM
kerosene
Feb 25, 2011 10:04 PM
Hurricane rider
Nov 19, 2008 02:23 PM
firemanron
Sep 6, 2007 12:57 PM
