one prob after another
Old 05-01-2013 | 08:45 PM
brads94f2's Avatar
Default one prob after another
I just got my first bike (94 f2) and so far re did the carbs, new battery, new r/r. Went for a bike ride and after a few minutes all the lights stopped working...headlight, brake, gauge lights! What can cause this? Thanks in advance
Old 05-02-2013 | 10:24 AM
brads94f2's Avatar
Guessing no advice
Old 05-02-2013 | 11:54 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Does the bike continue to run when this happens, or does it shut down?
Check the voltage after you lose these items, and see if the battery has lost some charge - you could also run tests on your stator, to verify it is indeed charging the battery.
Old 05-03-2013 | 12:49 AM
Optimus_Prime's Avatar
I had the same thought as JNS, maybe your charging system isn't working properly so your just running off your battery and eventually it just runs out of juice to keep the bike going. You mentioned you got a new R/R so check it's wired in correctly. I'd start checking voltages at various places to see if things are normal in the wiring.
ugly
08-29-2009 05:14 PM
tonymeredith
06-21-2009 11:41 AM
stoneguy1037
10-08-2008 04:50 PM
tdiv135
03-25-2008 05:24 AM
OCTOPUS
06-24-2007 03:48 PM
Quick Reply: one prob after another
