Need some guidance please
Old Apr 23, 2011 | 12:45 AM
Smoffler's Avatar
Default Need some guidance please
Okay I got my bike all back together I went to start it and it turns over and back fires through the carbs I've read this is due to timing so how do I do the timing?
Old Apr 23, 2011 | 10:44 AM
adrenalnjunky's Avatar
timing is fixed on this bike, you can only change it by replacing the pulse generator sprocket.
Which means as long as you have the pulse generator sprocket mounted to the crankshaft (you can't move it on the shaft - it only mounts in one position), and you have the hall effect sensor (again, can't be moved) plugged into the wiring harness (you wouldn't be getting spark if it wasn't plugged in) then you don't have a timing issue.
I'm guessing you don't have your firing order correct.
This bike fires 1-2-4-3, with the 1 & 4 plug run off the right side coil, 2 & 3 off the left. Right side coil need the plug with the yellow/blue wire plugged into it, and the left is the blue/yellow.
Old Apr 23, 2011 | 10:53 AM
ahh, but I've already posted that on another thread haven't I?
Just covering bases - just cause the firing order is 1-2-4-3, you still plug the plug wires in correctly from left to right 1-2-3-4. there's plug numbers on the wires - double check everything is in the right spot.
Spray starting fluid down the carbs and see if the bike hits that way - you might not be getting enough fuel to the carbs. Fuel pump issue maybe?
Old Apr 26, 2011 | 11:03 AM
Smoffler's Avatar
Okay so both blue and yellow on the right side?
RussianRider
Jan 19, 2013 02:49 PM
HASH
Aug 16, 2012 07:38 PM
Celo112
Jun 4, 2012 02:44 PM
$uperm3
Mar 25, 2011 09:47 PM
cebbeler7
May 28, 2009 08:37 AM
