Main fuse keeps blowing
Old Mar 28, 2013 | 11:40 PM
7starF2's Avatar
Registered Users
Default Main fuse keeps blowing
I recently had a drain on my battery that I narrowed down to a handful of bad wires. I decided to replace the whole wire harness. Its not a new harness, but it came off a working bike. After I put it in, I had no power, and found the main fuse blown. After replacing it a few times, I came to realise that it blew every time i plugged in the solenoid, or hooked up the battery after it was already plugged in. No clue why its doing this. Theres no exposed wires, no crossed wires, no metal on metal anywhere. Everything is plugged into the right spots as far as I can tell. Only things not plugged in are the headlight and turn signals, because none of those parts are currently on the bike.
Old Mar 29, 2013 | 03:41 PM
gtcole's Avatar
Welcome Crew
If you have a voltmeter , check that the solenoid is working properly and not shorting out on ya.
Old Mar 29, 2013 | 03:42 PM
74demon's Avatar
Is your battery hooked up backwards?
Otherwise, you have a power wire grounded somewhere.
Old Oct 16, 2019 | 01:26 PM
airforce75's Avatar
Default Main fuse
Run a continuity check from the solinoid to ground with the positive battery terminal disconnected. You should be able to trace your short easily.
jackojeff
Aug 14, 2012 05:19 AM
Samuel Petrasca
Feb 21, 2012 02:37 PM
Cbr6001234567
Aug 27, 2011 10:27 PM
SHugo
Sep 5, 2009 03:00 PM
drown42
Aug 26, 2009 04:06 PM
