LED sequential turn arrows not working right
Old May 2, 2020 | 08:34 AM
flitch's Avatar
Default sequential motorcycle turn signal not working
Originally Posted by adrenalnjunky
Hey - not all of us :-) Just don't post, since this place turned into a ghost town.
And I'm pretty sure my advice from 8 yrs ago is still valid. It needs a constant triggered input, not a on-off-on that a flasher relay puts out.
If you tapped off of the trigger wire coming out of the turn signal switch, but before it gets to the flasher, you could run that 12v+ back to these and they would work as intended until you turned the turn signal switch off manually. If you don't have stock style turn signals at all, you could probably just pull the flasher relay and jumper across the contacts and then use the factory wiring.
Hi, I have the same problem with my 98 f3, any chance of a wiring diagram. Cheers
all sorted, just take out the relay and short the connector. LED sequential works a treat
Old Sep 10, 2020 | 12:22 AM
Joe90's Avatar
Default Clarification
so my flasher is on the lead wire coming into the signal switch. I’m running sequential signal lights on the front and LED on the rear. So if I understand correctly I could what a flasher on each side for the rear output wires for the rear. I could then connect the sequential lines to the output wire ahead of the flasher. Of course I would have to remove the flasher on the feed line so the output would be constant. Does that sound like it would work to you?
Old Nov 29, 2021 | 08:47 AM
JonLe's Avatar
I have to just join this forum to thank you. Ive been sorting this problem for weeks. finally get it working perfectly.
As a noob in electrical stuff, that kind of frustration. Thank you so much
ambeos5
Aug 7, 2014 04:47 AM
mnguyen84
Apr 15, 2012 10:25 PM
xp3085
Nov 7, 2011 02:52 PM
ShaneF4i
Nov 23, 2008 10:46 PM
Antsurf
Jun 28, 2007 02:57 PM
