how do you start your f2 cold ?
I had this problem last year. I changed the battery and was amazed at how fast it started! The battery "seemed" good, but once I changed it, the engine cranked over considerably faster, and started withing a second, as apposed to the 10 to 15 seconds of cranking with the old battery.
It's not just the cranking speed that counts here, it the amount of voltage that is being delivered to the ignition system. The higher the voltage, the hotter the spark. When the engine is being cranked over by the battery, it may only be delivering 10 or 11 volts to the ignition system. A new battery may be able to crank the engine and maintain a 12.5 or higher voltage output.
The old battery didn't go to waste, I use it for my fish finder now.....
Hm... seems I spoke too soon.
The last week I've been getting the exact same symptoms as the op
(Cold start problem only below 50f (10c). Starts fine when warm).
Gonna start with the easiest and change the plugs.
It's been 3 years and 17.000km (11000mi) since i last changed them.
Have been wantng to change them for some time now anyways, just
havent gotten around to it.
Cleaned and synced the carbs last year and its been starting and running
perfectly since then, so im hoping its just something easy like the plugs.
To be continued...
To be continued...
I was just looking at it like the same situation as building a motor for a racecar - the first time you try to crank it, you cut the spark so it can't crank, thend turn the motor over on the starter until you see the oil pressure come up. (Or the light go off) The first few seconds after start up are hardest on motors since the oil hasn't really started flowing yet. Might as well try to make it easy as possible on an 18 year old machine, in my case :-)
I would only think it beneficial if the motor has been sitting dormant for long stretches of time, or maybe right after an oilchange. An engine run regularly probably has enough residual oil in all the galleys and journals to not be anything major.
