headlight problem
repainted my bike and put back together today and now my light doesnt work. checked the wiring in the starter switch and fuses everything seems good but i have no power at the socket. any ideas?
Does the bike run and is the headlight the only component not working properly? If so, I would recheck the wires going into and out of the starter switch again. The solder joints in there are a classic F2 weak point.
i have fixed the switch problem before and the wire is still attached. and i have3 the bulb hard wired out of the fuse block right now so the bulb is good. those were my first 2 ideas too.
