Fuel Tank Restoration
Old 09-13-2023, 07:30 PM
KrwoodsRN's Avatar
Default Fuel Tank Restoration
Hey,
trying to bring my ‘91 CBR back to life after sitting for 12+ years. Tank has a nice layer of rust. I planned on using the por-15 motorcycle fuel tank restoration kit. My question is do I need to do anything specifically with the breather and overflow tube? How exactly do they work inside the tank? When rolling the tank to get the sealer throughout do I need to worry about it clogging those off? Any advice would be appreciated. Thanks!
Old 09-14-2023, 01:34 PM
Phil314's Avatar
Overflow tube goes all the way through the tank, so nothing will get in it.
Breather tube is large. The gas tank sealer should end up as a thin sealing coat, no where near thick enough too clog anything.
You could always run a wire up the breather tube afterwards, if you want to be sure.
There is some debate if sealer kits are needed at all.
I know several people who have cleaned tanks of loose rust, then just filled then with gas and used them without problems.
and when filled with gas, they really shouldn't rust.
Just doesn't let them sit for years 1/2 full - good advice for any gas tank.
Hackbart
04-15-2021 09:06 AM
h2opro
07-05-2011 08:51 AM
bigjohnstud4200
10-15-2008 11:28 PM
jayson_219
11-16-2006 08:57 PM
Quick Reply: Fuel Tank Restoration
