First ride since winter?!
Old Mar 29, 2011 | 05:54 PM
pdcbrf2's Avatar
Default First ride since winter?!
First it was feezing but glorious at the same time. Second After a few miles of riding my RPM 's started hanging at 5-3k and then it would drop like normal. Also when that started to happen the throttle was slow to respond. I replaced the plugs, cleaned the carbs and did an oil change. I messed with the throttle cables when I had the carb off to get it snapping back. Im just confused. Is it the pilot jets? I thought I cleaned the pilot jets when I was in there. Or is it just the pilot/idle screws. I already have them set less then stock. Also going with the other thread I started, the bike stalls whenever the choke is put on at all and wont start if the choke is on. A little more knowledge from those that are much wiser then me is needed. Thank you in advance
600f4ilover
Feb 4, 2011 08:16 AM
Tawny529
Jan 3, 2011 01:09 PM
Bordo
Rides
Aug 13, 2010 03:16 AM
hypeshipe
Mar 17, 2009 04:19 PM
mofun08
Sep 22, 2008 05:05 PM
