First ride since winter?!
First it was feezing but glorious at the same time. Second After a few miles of riding my RPM 's started hanging at 5-3k and then it would drop like normal. Also when that started to happen the throttle was slow to respond. I replaced the plugs, cleaned the carbs and did an oil change. I messed with the throttle cables when I had the carb off to get it snapping back. Im just confused. Is it the pilot jets? I thought I cleaned the pilot jets when I was in there. Or is it just the pilot/idle screws. I already have them set less then stock. Also going with the other thread I started, the bike stalls whenever the choke is put on at all and wont start if the choke is on. A little more knowledge from those that are much wiser then me is needed. Thank you in advance
