F2 F3 Swap
Old May 14, 2023 | 05:08 AM
rokitrick's Avatar
Default F2 F3 Swap
Crashed a 92 F2 and bent the frame. Will the F2 engine and shock mate up to an F3 frame and swingarm ?
Or are they that different ?
Thanks
Rick
Old May 14, 2023 | 01:55 PM
rockpool's Avatar
Frames are different part numbers, but they look very similar and the engine mounting hardware is the same..
https://www.hondapartshouse.com/oemp...54be2c55/frame
https://www.hondapartshouse.com/oemp...54bedd54/frame
Same story for the swingarm - looks identical in the pictures but has different part numbers.
Old May 14, 2023 | 01:57 PM
rockpool's Avatar
Some have said the F2 and F3 frames are the same, the main difference is the shock linkage which prevents an F3 swingarm being used on an F2 frame - since you're going "all F3" looks like you might be in luck!
https://www.bcsportbikes.com/threads...3-or-f4.16758/
Old Nov 11, 2023 | 04:46 AM
rokitrick's Avatar
Thanks
Rick
Since i had a Penske shock, i kept with F2 and found a nice straight frame and swingarm. Made it simple
One thing I did find is that the F3 swingarm has a larger bolt. You'd need to drill out an F2 frame to use an F3 swingarm
So i have an F3 swingarm, bolt, and bearings if anyone needs one
hardhat_harry
Jan 16, 2009 08:05 PM
EvilJames
May 16, 2008 11:14 AM
Philo
Sep 20, 2007 01:36 PM
gnicholls7
May 12, 2007 02:01 AM
bait
Feb 7, 2007 03:38 PM
