Clutch Cable Keeps Getting Stiff
Old May 18, 2012 | 12:39 PM
RoadrashCBRf2's Avatar
Exclamation Clutch Cable Keeps Getting Stiff
Well Okay my F2 recently received a new Second and Sixth Gear, (When I bought the bike it was fine but (1,000 Miles later) Second gear went out and we paid the dealer we bought it from to fix it. Well anyways I got my bike back and it was fine but then a day later I rode it and my clutch cable was so stiff that it was causing my clutch to disengage. So I called the dealer and they said to loosen the clutch cable adjustment, I gave it a bunch of slack and it was fine for a day then it went back to being tight. I had no more room on the lever to give it more slack so I called and they said to adjust it then on the bottom end. So I gave it more slack on the clutch case and then a few more days later it got tight again... Well so I brought it back to the dealer and said they need to fix it, (it was never right since I first got it). They said that the person who installed the clutch didn't soak it in oil so they said that should fix it. Well then a day later I rode and It tightened back up on me again. So I adjusted the lever once again, and decided to go on here.
What could be the cause of this or case? They said my clutch had plenty of life on it? Dirty Cable, Do I need a new cable? Is this a common issue?
Please help me.. It's been in the shop longer than I have ridden it.
Old May 18, 2012 | 01:20 PM
Shadow's Avatar
Is your cable needing oil ? Could be.........
Maybe the cable is worn/has damaged filaments in the cable and it's sticking inside the cable carrier.
Not one I've heard of before......
Old May 18, 2012 | 04:22 PM
underground-mpyre's Avatar
Get some lubricant spray bottle with Teflon. It will loosen anything in the cable that might be binding up. If it isn't that, you have a head-scratcher.
Zandaloo
Aug 22, 2013 03:26 PM
Daviator
Mar 5, 2013 03:48 PM
axehind
Jul 1, 2011 07:54 AM
reddog952
Apr 28, 2011 02:54 PM
cyber00677
Jun 23, 2007 06:17 PM
