Aftermarket Guage cluster hookup
I am helping a friend install an e-bay aftermarket (cheap) gauge cluster unit on an F2. With the tach wire connected to the new unit, the RPM signal shows about double what the actual engine speed is! I am guessing this is because each coil fires TWICE in each power cycle (each coil is responsible for 2 cylinders). I can't find any way to program the gauge unit to compensate for this.... Is there any other way to get the tach to read correctly?
I put a Suzuki Katana tach on my F2 one time, it seemed to work good until I got to the track, RPM's were pegged. I fixed it when I got home, used it for a year or so, but I dont remember which way was wrong or which way was right. I either had one wire going to a coil or 2 wires going to both coils. I eventually went back to original tach with speedo ground off by the highway. I didnt ground it, I got it dirt cheap.
