1st Problem Encountered
Old Apr 22, 2011 | 10:33 PM
SluttyLancer's Avatar
Default 1st Problem Encountered
So I was riding today and I tried braking with the rear brake only to find out it depressed all the way down, with no braking power what-so-ever. Then I just let off and pushed again and it worked. Im guessing its just brake fluid that needs to be replaced but Im not too sure since Im new to bikes. Does anybody have any ideas to what it could be or where the reservoir for the rear brake fluid would be?
Thanks
Old Apr 22, 2011 | 11:14 PM
buickid's Avatar
Time to flush/bleed the brakes! The reservoir is connected to the rear master cylinder with a hose, which is connected to the rear brake pedal. Just follow the trail and it should be there. Its a small circular shaped plastic container
Old Apr 24, 2011 | 10:22 PM
Ok cool, Ill check it out tomorrow,
Thankss!
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
RR4me
Jul 19, 2006 09:03 PM
