Detailing Discuss detailing your ride within.
Repairing Stratches on Fairings
Old Jun 23, 2007 | 11:08 PM
Nauree's Avatar
Default Repairing Stratches on Fairings
Im going to sand down some stratchs and repaint my fairings. What do I do to make the paint look shinny after I'm done?
Old Jun 23, 2007 | 11:56 PM
D2VW14_20's Avatar
Default RE: Repairing Stratches on Fairings
Ae they really deep scratched???If not, try rubbing compound before you do a complete sand. If there are just do a few layers of paint then clear coat.
Old Jun 24, 2007 | 12:06 AM
Nauree's Avatar
After I sand them down smooth all I need to do is wash the surface, paint over it, and clear coat?
Old Jun 24, 2007 | 12:52 AM
D2VW14_20's Avatar
Yeah, if you have access to an air compressor, blow it dry after you wash is, or you can wet sand it as well. Then paint one coat, dry, sand, paint, dry, paint, clear, dry clear.
Old Jun 24, 2007 | 01:38 PM
Nauree's Avatar
Wait, if I sand it after I paint one coat wont it take off the paint I just put on?
Old Jun 24, 2007 | 09:00 PM
D2VW14_20's Avatar
Haha, no, you dont do a complete sand, you scuff it up and make sure everything is alright, if you want to do it right, I would prime it first though.
Old Jun 27, 2007 | 07:50 PM
AudiCBR's Avatar
lol just goto the body man and say "fix this"
Old Jul 15, 2007 | 02:27 PM
Nauree's Avatar
Ok, I'm about to start this project. What grits sand paper do I need? After its all painted would any clearcoat work? Also, should I wax it all after I'm done?
Old Jul 15, 2007 | 02:47 PM
Nauree's Avatar
Also, to fix dull areas that I guess are rub marks, areas still painted but arn't shinny, do I just need to put clearcoat on it or can I wax it?
Old Jul 19, 2007 | 09:09 AM
urandaman's Avatar
try clay bar or a rubbing compound on dull areas..
for sanding. hit the plastics with a 320 to cut thru the orig paint a bit, then hit it with 600grit(wet sand paper) wipe it down with a degreaser, and hit it with a tac cloth, prime it or paint, which ever way you want to go, once you get the first coat, and its cured a bit, hit it with 600 just to get any bumps out from the paint globbing up. wipe it down again, hit it with 2 coats... wait about 10mins til you do the second coat. once thats cured, sand it down with 1000grit, wipe it down and clear it with 2 coats, once that cures, hit the clear with 2k gritt, then get some rubbing compound and buff it out and you should be good to go... thats how i painted my last truck and jeep, and they looked damn good. i may have forgot a step or 2 but ya.. general idea..
and if your painting on the outside.. spray everything down with water to hold the dust down
bullroarer
Oct 24, 2015 08:24 PM
DRam
Sep 4, 2014 10:37 PM
GTS1105
Dec 5, 2007 11:18 AM
Ruftags
Dec 8, 2006 03:22 AM
carmich132
Sep 23, 2006 09:29 PM
