Repairing fairings
Old Sep 18, 2006 | 02:48 PM
carmich132's Avatar
Default Repairing fairings
How would one go about fixing a crack in the mid-fairing right next to my frame slider (it's about 2 inches long and it seems like you should be able to bondo it or something and then paint it...also, how to fix scrapes in the lower and tail fairings...I'm not sure if they make a filler that works better than something else. Any help would be great.
Old Sep 18, 2006 | 02:49 PM
Blackdog F4i's Avatar
Default RE: Repairing fairings
go to your local autobody supply store. They sell fillers specifically for plastic.
Old Sep 18, 2006 | 06:44 PM
jzcbr600's Avatar
plastic weld is great for cracked plastics.
Old Sep 23, 2006 | 09:29 PM
Pugetpower's Avatar
Remove fairing. Clean & roughen with course sandpaper, inside of fairing couple of inches on each side of crack. Tightly tape good side of fairing exactly in its original position (use duct tape or maybe that blue painters tape). Saturate both sides roughend crack (inside of fairing) with polyester resin. Apply fiberglass cloth over crack. Apply more resin. Let cure. Sand rough edges. Save all materials for the next crash & burn.
bullroarer
Oct 24, 2015 08:24 PM
DRam
Sep 4, 2014 10:37 PM
GTS1105
Dec 5, 2007 11:18 AM
Nauree
Jul 19, 2007 09:09 AM
Ruftags
Dec 8, 2006 03:22 AM
