Yoshi Bolt on Clamp
Old Dec 27, 2009 | 09:56 PM
shaneo2770's Avatar
Default Yoshi Bolt on Clamp
Hey guys,
I just bought a 2nd hand Yoshi bolt on from E bay,
It doesnt come with the clamp though.
Does anyone know where I can find just a clamp?
I have heard if you cut them down to a shorty pipe you dont need a clamp?
Is this true.
Cheers
Old Dec 27, 2009 | 11:25 PM
randyjoy's Avatar
I have a bolt on Yoshi on an 03, it uses the stock clamp (if you are referring to the clamp that holds it on to the bike near the passenger peg). I looked at the parts fiche, and it doesn't look like that strap-clamp is available by itself from ronayers or bikebandit. Might try a dealer.
Old Dec 28, 2009 | 03:14 AM
shaneo2770's Avatar
So does the exhaust clamp fro the stock honda exhaust fit it?
Old Dec 28, 2009 | 09:25 AM
Kuroshio's Avatar
I'm needing a strap clamp myself. 1 lowside too many (ie. 1) has mine breaking
Old Dec 28, 2009 | 09:41 AM
randyjoy's Avatar
I'll check to make sure, but that's what I remember from when I put the Yoshi on (but it's been several years, so my memory could be failing me). If it is different, you'd probably have to go to a Yoshi dealer or contact Yoshimura themselves. I'll check today...
Old Dec 28, 2009 | 08:04 PM
randyjoy's Avatar
They say that memory is the first to go, and I don't recall what is next.
The clamp is different. I pulled out my very old stock can, the clamp is welded to the can. I had modified the original can and had fabricated a new clamp using a 1" aluminum strip and a little machining.
I'd contact Yoshi direct at their customer service to see if they have the clamp available that comes with your can.
It's welded to the can. You either need to do some fabricating or get a new (used) stock can or a slip-on.
NateDieselF4i
Jun 30, 2011 01:04 PM
graygeezer
Jun 16, 2011 11:41 AM
shaneo2770
Jan 19, 2010 01:41 AM
shaneo2770
Jan 7, 2010 05:12 PM
snampro
Jan 3, 2005 10:32 PM
